kappa Publicado 30 de Diciembre del 2010 Reportar Publicado 30 de Diciembre del 2010 (editado) Renault Diagnostic Can Clip v104 (2010) Multilanguage | 1.57 GB Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues. Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions. It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported. Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved. Program dealer car diagnostics Renault, Dacia, Samsung. Year: 2010 Version: V104 Developer: SPX Platform: Win 2000, XP, Vista Language: English (Multilangual) Medicine: Present FULL Instructions : Before installing please do the following steps: 1. Uninstall previous version of Renault CAN-Clip if you have 2. IF your 1st installation: Run Crack.reg After installation finish & you will reboot, you will get SPX Registration.... To avoid PERMANENTLY this, do the following steps: 1. Alt+Ctrl+Del (Kill process RSRWin.exe) 2. Delete RSRWin.exe (in C:\Windows) 3. Use Regedit (and Delete "ALL" values with name RSRWin) 4. Reboot your machine!!! 5. NO MORE flash for SPX Registration... Before your 1st Running with the program make those steps: You NEED to have 1 Renault Car (and ALWAYS Renault clip running-working) when you have Renault Car!!! 1. Connect your Clip Sonde Can Interface 1st in your Car (OBD Slot) 2. Turn Ignition ON (NOT Engine running) 3. Connect your Clip Sonde Can Interface via USB cable with your computer 4. Start to installing ALL the Drivers (that they will be appearing) and you can find those in: C:\WINDOWS\system32\drivers or from this DVD in the folder "CAN-Clip Drivers". 5. You must INSTALL 4 Drivers (4 TIMES the same thing) After you finish, you can RUN now finally your CAN-Clip Software..... Editado 26 de Mayo del 2011 por kappa Citar
