cual es el codigo que pide? gracias
¿Que cómo que pide código?
¿Tú que te has bajado?
te doy la enhorabuena por ser tan guay! me has ayudado a oir musica desde la pda en el coche y me he enterado de todos los radares!!!
Sigue asi tio!
Gracias
pues valla putada! yo utilizo el programa tcpmp en vez del wm por ser mas facil de manejar(para mi gusto). esta pda siempre me ha dado rollos con la sincronizacion y con el bt. la htc p4350 es la que busco pero la han quitado del mediamarck.
De todas formas muchas gracias por tu respuesta.
(no hay otro programilla de marras?)
  • 10 meses más tarde...
A los que no os funcione leer esto, yo lo probare, tampoco me funciona.
I just got a Bluetooth headset, and it took me forever to find out how to get it working. The audio's not great; music doesn't sound good, but VoIP doesn't sound bad. I found the registry info on a BrightHand forum ( http://discussion.brighthand.com/showthread.php?s=&threadid=85322 ).
* Change the following registry keys:
--- HKLM\SOFTWARE\Widcomm\BtConfig\Services\0005\Enabled
----- Change value to 1.
--- HKLM\Drivers\BuiltIn\WaveDev\Dll
----- Change value to BtCeIf.dll
* Soft-reset your handheld
* Open the Bluetooth Manager program (click on the Bluetooth icon on the bottom-right corner of the screen and select "Bluetooth Manager")
* Click the New menu and select Connect!
* In the list of profiles shown by the Connection Wizard, there should be a new one at the bottom called "Connect a headset". Double-click this entry.
* Click the Device box and select your headset (you might have to put your headset into pairing mode to find it)
* If you get an Authentication screen (requiring a passcode), enter the passcode given in your headset's manual (for my BlueTrek headset, it's 0000)
* This should finish the connection. You can create a shortcut on the next screen, if you'd like. Use that shortcut to connect your headset.
* When you attempt to connect to the headset, your headset will indicate an incoming call; answer the call to activate the connection.
Note that, when you change HKLM\Drivers\BuiltIn\WaveDev\Dll, your audio (speakers and mic) will only go to Bluetooth, not your speaker. To get audio through your speaker again, you have to change HKLM\Drivers\BuiltIn\WaveDev\Dll back to wavedev.dll and soft reset your handheld. Also, some people have reported that their iPAQ's require a soft reset to turn back on when WaveDev is changed; I've only had this happen once, and it goes away when you change WaveDev back to wavedev.dll and reset.
:scared:Bueno vp1,el resultado de la prueba malo, probado en pda mioP550 con windows mobil 5, falla sale lo siguiente
0BtMusic.001 No existe una aplicacion asociada com "0BtMusic". Ejecute la aplicacion y despues abra el archivo desde la misma.
BTMUsi-2, No existe una aplicacion asociada com "BTMUsi-2". Ejecute la aplicacion y despues abra el archivo desde la misma.
Bueno investigando un poco por aqui :typing:y por alli :typing:,he conseguido instalarlo en pda,lo que hacia es descomprimir el archivo y no hay que descomprimirlo con el explorador de archivos se instala, de momento instalado cuando lo pruebe te dire.:bounce3::bounce3:
Salu2.
Pd. el mensaje anterior olvidalo
Nada no hay forma de que funcione,programa instalado y me pedia actualizar microslf.net compact framework, he actualizado la pda y el programa se abre pero no manda el sonido al manos libres, seguire intentandolo:thumbs_down:>:(
Mira que lo siento. En xperia funciona a la primera.
Pasate por htcspain en la seccion descargas. Hay tres o cuatro programas de este tipo. Yo uso BT audio toggle o BT music segun la pda.
Preguntale a maestro kachoperro, pues a mi no se me ocurre nada si ya instalaste el microsoft netframework 3.5 o similar. Sino pregunta en algun foro de pdas. Alguien mas ducho que yo en el tema te echará una mano.
Lo primero que hay que hacer es conectar el bluetooth, parece una tontería, pero a mucha gente se le escapa.
El BTaudiotogle funciona como un pulsador, si se ejecuta, el sonido pasa al bt, se vuelve a ejecutar y queda normal.
Y luego es posible que el hardware de la PDA no admita la función
