Ola a todos
estive pesquisando e escolhi comprar um Redline
contactei escortradareuropa para perguntar o melhor sitio para o adquirir
e me disseram o seguinte:
Hi,
The best detector for Portugal is Valentine One Euro from valentine1europe.com
It is our competitor product but will work better in Portugal. It is also most sold detector in Portugal.
Hi,
Escort Redline does not work in Portugal, Escort Redline has no European version and is guaranteed not to work in Europe correctly at all. We sell Redline only to countries where there is only USA type radars.
Also there is no need for undetectable detector in Portugal as the only countries in Europe that uses Spectre are Finland and Estonia, Belgium. There is no such devices in Portugal.
I dont understand why this company sold You Redline without asking about where it will be used. And this is not he first time they do this.
Return the Redline and buy a proper European version detector, otherwise You stay partially unprotected.
entretanto eu respondi :
hmmm,
whatch this video if you can
it´s the same settings must be done in valentinev1, for that it needs a firmware to europe
Skip to 17:44 for Ka band segmentation.
e me responderam de volta:
It is not entirely true. Most of our products has Ka band segmentation but it has nothing to do with European mode. There is radars like Multaradar CD and other low powered radars that needs special algorithms inside the device. And we build them inside European models only.
Also even Escort X50 Euro has better detection distance than Redline and is cheaper.
We are the manufacturer, not reseller, so we know our stuff.
Redline is not suited for Europe, it is a false claim.
alguem me tira a duvida se Valentine supera REDLINE ? e se REDLINE funciona mesmo ou nao ?
aqui em PT nao consigo falar com ninguem que tenha um
El redline que se vende en esta casa es el modelo europeo que acota la banda ka que se usan en europa,españa y portugal ademas de ser un equipo indetectable cosa que el valentine one y el x50 no lo son .....y si quieres tienda autorizada en españa para la venta de escort este es el sitio ...
mister frecuencias
  • 3 meses más tarde...
Ola novamente
ja se passaram 4 meses e o redline ja me poupou €´s e chatices ca em casa :)
estou muito contente com ele
no entanto nesta ultima semana disparou 3 vezes o aviso de LASER,
2 delas na zona da Sobreda a ultima na zona de Palmela
so na 3º vez é que consegui identificar a origem do Laser, um destes carros novos da GNR , cinzentos e verdes, vinha com os pirilampos ligados e ligeiramente mais depressa que todo o resto do transito, presumo que o Falso Alarme tenha proveniencia nos Strobes destes novos pirilampos, acho que os Sr´s GNR´s nao vinha de cruise control ligado, pois tenho lido que estes novos carros têm ou podem ter sensores de distancia para o carro da frente (opçoes de cruise control) mas presumo que isto so esteja ON quando o cruise control esta ligado, correcto ?
Puede ser, pero me resulta raro, a mi no me ha dado ningún fallo de los que dices. De todas formas, si te pita el láser, ya te han multado. Podrías desconectar el láser, ya que, por desgracia, cuando te avisa, ya es tarde.
CLF: dice que hay nuevos coches de esos medio automáticos, que frenan solos por cercanía con el que le precede, y cree que estos sensores, le hacen pitar el láser de su redline. Creo que GNR es el equivalente a la G.C. De aqui.
Ola, fui traduzir o texto:
Ola nuevamente ja se pasaron 4 meses y el redline ja me ahorró € y chatices ca en casa estoy muy contenta con él sin embargo en esta ultima semana disparó 3 veces el aviso de LÁSER, 2 de ellas en la zona de la Sobreda a ultima en la zona de Palmela so en la 3º vez es que conseguí identificar el origen del Láser, uno de estos coches nuevos de la GNR (Guarda Nacional Republicana), cinzentos y verdes, viña en sentido contrario ao meu con los pirilampos conectados y ligeramente más deprisa que todo el resto del transito, presumo que la Falsa Alarma tenga proveniencia en los Strobes de estos nuevos pirilampos, creo que los Sr´s GNR´s nao venía de cruise control conectado, pues he leído que estos nuevos coches tienen o pueden tener sensores de distancia para el coche del frente (opçoes de cruise control) pero presumo que esto so esté ON cuando el cruise control esta conectado, correcto ?
acrescento que quando el coche da GNR se cruzou com o meu, o redline se calou, acho que medir velocidade com pistola Laser, la misma tiene de estar parada, correcto ?
nas vezes que me apitou Laser, so uma das vezes é que ia mais depressa mas mui pouco, limite de 50 e eu ia 60 ou 65kmh
meu coche tien matricula 100% reflectora á la frente e trasiera, pero que nao sei como la pistola de LAser se compuerta a focar
Ola novamente
vou manter el Laser ON pero que desta maneira poderei saber se utilizam ou nao Pistolas de Laser para medir trafego, eu sei que nao me vale de muito, para el Laser tenia que ter jammers, mas assim posso saber o que tem los policias en suas manitas :)
Boas... bom ver que existem portugueses por aqui....ainda mais com Redline.... adquiri recentemente o meu, tenho as configurações todas correctas, mas das 3 ou 4 vezes q apanhei radares apitou sempre em cima, na Auto Estrada é completamente para esquecer, quando apita já passei o radar.... Olaio consegue mesmo boas distâncias com o detector?
  • 3 semanas más tarde...
Essa também foi uma das minhas questões... e de facto, é superior, principalmente porque é indetectável aos detectores de detector (importante se viajas por exemplo para Espanha) e não te dá falsos alarmes. Em termos de distâncias, e de tudo o que vi quer por aqui, quer em videos pelo youtube, o Redline é também superior... certifica-te é que não tens vidros atérmicos... eu estava a ter más distâncias porque tenho vidros atérmicos.... quando experimentei noutro carro as distâncias foram muito boas... mas isto aplica-se obviamente a todos os detectores portateis.
Olá tudo bem.. Eu também tenho o redline há já algum tempo e posso dizer que funciona muito bem em Portugal.. Tenho algumas detecções de 1km:)!nunca menos de 400mts..o laser a mim próprio vezes também dispara, nos pórticos da scuts e portagens!! Em Portugal há um radar de laser, muito usado em Lisboa, o vitronic poliscan!! Mas é quase impossível detecção a esse.. Abraço
Podes desligar o laser
Só há multanova 6f em portugal.
Tb tens os radares de banda k dos semáforos de controlo de velocidade mas esses não dão multa lol
Olha que não.. Além do multanova há o multaradar C e o vitronic poliscan!!! Estes dois últimos muito usados na zona de Lisboa!!
