pepe.discoduro Publicado 11 de Diciembre del 2006 Reportar Publicado 11 de Diciembre del 2006 Un amigo de canada me ha comentado que alli llevan estos detectores para los radar, dice que va muy bien. Cheetah Radar Detector Cheetah is the most discrete radar detector on the market today, simply attaches to your interior mirror and a power supply. Warns of active Radar operated speedtraps and also active laser operated speedtraps usually located in accident blackspot areas giving increased safety at the critical places. The unique and discreet design of The Cheetah speed trap detector means you don't need to remove it at the end of each journey. There are two integrated expanding clips which fit over most sizes and shapes of rear view mirror, leaving your dashboard and sun visors clear. Simple to fit and totally user friendly, The Cheetah provides an invaluable 'sixth sense' guide to staying within the speed limit and keeping your licence clean. The Cheetah speed trap detector gives advance warning of fixed and mobile GATSO cameras up to 400 metres away and hand held radar or laser guns up to 1/2 mile. The superior quality panoramic mirror gives enhanced rear view vision with greatly reduced blind spots. It is specially treated with an anti-glare tint to ease driving at night. The Cheetah speed trap detector comes with a 2 year repair or exchange warranty as standard. Available now from the Radar Detector Shop for only £199.99 LINK A LA WES: http://www.radar-detector-shop.co.uk/products/cheetah-radar-detector.htm Desde luego es disimulado que te cagas, y va lo mas arriba y viendo la carretera de pei madre. Citar
A300 Publicado 11 de Diciembre del 2006 Reportar Publicado 11 de Diciembre del 2006 http://www.todoradares.com/foro/showpost.php?p=18&postcount=1 http://www.speedcheetah.com/scshop/index.php Citar
Carlos996 Publicado 12 de Diciembre del 2006 Reportar Publicado 12 de Diciembre del 2006 El Cheetah es muy buen detector, sobretodo el Sentinel remoto... pero los cheetah solo captan la banda K. No capta ninguna otra frecuencia, y aqui en España, el 99% de los radares son en Banda Ka. La razon es que en GB, de donde es Cheetah, la mayoria de los rtadar son en Banda K y la Ka no se emplea en GB. Citar
juinta Publicado 12 de Diciembre del 2006 Reportar Publicado 12 de Diciembre del 2006 El Cheetah es muy buen detector, sobretodo el Sentinel remoto... pero los cheetah solo captan la banda K. No capta ninguna otra frecuencia, y aqui en España, el 99% de los radares son en Banda Ka. La razon es que en GB, de donde es Cheetah, la mayoria de los rtadar son en Banda K y la Ka no se emplea en GB. Oye venerado master...y pregunto yo, estos Cheetah (tienen nombre de queso)...tienen algún tipo de filtrillo GSM, porque sino es el festival de las falsas alarmas... Citar
Carlos996 Publicado 12 de Diciembre del 2006 Reportar Publicado 12 de Diciembre del 2006 ya te vale maese Juinta ... ahora en serio, pues la verdad es que no lo se, pero tampoco he oido de problemas de que los moviles GSM causaran problemas, aunque pensandolo bien, con ya las gasolineras, supermercados, bancos, y demas en banda K, ya seria una discoteca con o sin filtro de tel moviles! es el problema de muy bueno para un pais, malo para otro. Citar
juinta Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 ya te vale maese Juinta ... ahora en serio, pues la verdad es que no lo se, pero tampoco he oido de problemas de que los moviles GSM causaran problemas, aunque pensandolo bien, con ya las gasolineras, supermercados, bancos, y demas en banda K, ya seria una discoteca con o sin filtro de tel moviles! es el problema de muy bueno para un pais, malo para otro. Vaya cacao tengo, a eso me refería a las falsas por K, perdón, entonces, en este caso, quien lleve un "chetos" de estos en los UK lleva una discoteca ambulante, no?, la única manera de sobrevivir sería un RP-antena con la K al 40-50%... Citar
SANdokan Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 Desconozco si falsas alarmas por GSM se "cuelan" también en Banda K, pero las q solemos padecer con el 975R son procedentes de la banda Ka, tanto con el 2º led como con el 4º. Citar
Carlos996 Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 chetos... je je... Totalmente, es que ademas radares en K hay miles en GB pero son todos fijos, y ademas tienen muchos de bandas de induccion y specs con lo que en GB ahora lo que se usa es solo avisadores GPS practicamente, porque con un detector es una discoteca ambulante y no te detecta todos. Los unicos mobiles que tienen son los Ku (que estan cayendo en de suso), y las pistolas laser como el lasercam que se colocan en furgonetas y disparan desde la parte trasera que estan siendo cada vez mas populares. Citar
juinta Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 aaaais...lo que no sepa este chico...me voy a vivir a los UK que con un Rp-antena EUropa y un peretronic lo tienes todo bien sujeto... Citar
SANdokan Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 chetos... je je... Totalmente, es que ademas radares en K hay miles en GB pero son todos fijos, y ademas tienen muchos de bandas de induccion y specs con lo que en GB ahora lo que se usa es solo avisadores GPS practicamente, porque con un detector es una discoteca ambulante y no te detecta todos. Los unicos mobiles que tienen son los Ku (que estan cayendo en de suso), y las pistolas laser como el lasercam que se colocan en furgonetas y disparan desde la parte trasera que estan siendo cada vez mas populares. O sea, q allí tienen prácticamente la guerra perdida, no? Esperemos no ir por los mismos derroteros, aunque tal y como se está poniendo la cosa, pinta mal... Citar
yawy Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 O sea, q allí tienen prácticamente la guerra perdida, no?Esperemos no ir por los mismos derroteros, aunque tal y como se está poniendo la cosa, pinta mal... Yo creo que todo lo contrario, ojala aqui se dejasen de radares moviles en banda Ka y se limitasen a radares fijos y pistolas laser, que te compras un RP y un parktronic y arreando, nosotros entre los fijos, los moviles de Ka, los moviles de laser y los moviles de autovelox estamos mucho mas jodidos. Citar
juinta Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 Yo creo que todo lo contrario, ojala aqui se dejasen de radares moviles en banda Ka y se limitasen a radares fijos y pistolas laser, que te compras un RP y un parktronic y arreando, nosotros entre los fijos, los moviles de Ka, los moviles de laser y los moviles de autovelox estamos mucho mas jodidos. si todo se resume a lasercam, fijos (varios tipos) y ku...puedes llegar a protegerte un 99.99%...(siempre existe la posibilidad de fallo del equipo y que tu reacción anbte una alarma de radar sea la correcta Aquí en la España de pandereta tenemos todo eso (lasercam, fijos varios, ka en vez de ku) y los puñeteros velox camuflados...con lo que nunca podrás ir un 100% protegido... Citar
Carlos996 Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 Si, yo prefiero muchos banda K fijos, tripodes Ku, y lasercam de los que uno puede protegerse, que autovelox invisibles y multanovas escondidos. Encima en GB los detectores son legales y todo. Citar
asgcoupe Publicado 13 de Diciembre del 2006 Reportar Publicado 13 de Diciembre del 2006 ... Encima en GB los detectores son legales y todo. :meparto: tu veras si llevar un detctor alli tiene que ser peor que un castigo... quien aguanta eso pitando todo el rato... jejeje Citar
DYK Publicado 14 de Diciembre del 2006 Reportar Publicado 14 de Diciembre del 2006 :meparto: tu veras si llevar un detctor alli tiene que ser peor que un castigo... quien aguanta eso pitando todo el rato... jejeje Aqui , ya mismo vamos a estar peor con la "chicharra" cantando sin parar y por si tubieramos poco , ahora nos ponen radares de "induccion" que se pondran en marcha para la campaña de navidad y hay un monton. S2: Citar
