Yes! Translated into English:
This is what you should change -from the factory settings in the Programming Mode- to get maximum detection distances and minimum false alarms in Spain:
1- from arrow up to down (X band off)
2- from arrow up to down (K band off)
5- from arrow up to down (more responsive in Ka band)
j- from arrow up to down (POP mode off)
u- from arrow up to down (Euro mode on)
And also, after Euro mode is on, an "U" appears in the screen. You should push it for 2-3 seconds and it will change to "u". Doing that, you are turning K band off because when you turn Euro mode on, K band is automatically activated.
What was happening to you was that you had K band on so this is why you were getting so many false alarms. In Spain and Portugal you can or you must turn K band off because there are no mobile radars using K band. In most countries of Europe you should have K band on, unfortunately.
PS: I would also change from arrow up to down in the section 6 of the programming mode (Ka false alarm guard) but then you get some more false alarms in Ka band. I think you could improve a little bit Ka radar detection with this feature in off but I have not really proof that. So it is just a personal feeling.
  • Respuestas 57
so for Portugal....
same configuration of Spain...
use euro mode for city - "u"
some user said that i should tun off euro mode, you agree? he says that the radars are a little mangled around 100Mhz
K band in portugal is used for traffic light??? maybe this option on its a good choice
so for Portugal....
IN ENGLISH:
Yes, Portugal and Spain should have the same setup.
About turning off Euro mode... well, you could have Euro mode off but then you should use a vertical bracket for the V1. Or you could have it on but then you will miss some decalibrated mobile radar. But the question you should answer is: does the police in your driving zone use a decalibrated mobile radar? If yes, turn it off and put it vertical. If no, turn it on and, if possible, put it vertical.
With Euro mode off you loose detection distance so it's better to have it on. With the V1 in vertical position you increase your detection range so you compensate what you loose when you turn Euro mode off.
There are no mobile radars in K band neither in Portugal nor Spain so keep it off. Take into account that K band is used for most of automatic door sensors so you will have many false alarms. There is no need to have K band on in Portugal or Spain.
EN ESPAÑOL:
Sí, la configuración es la misma en España que en Portugal.
Acerca de desactivar el modo Euro... puedes tener el modo Euro desactivado pero entonces debes utilizar un soporte vertical para el Valentine One. O puedes tener el modo Euro activado y no detectar algún radar descalibrado. Pero la pregunta que debes responder es: en tu zona hay radares descalibrados?? Si es que sí, desactiva el modo Euro y pon el Valentine One en vertical. Si es que no, mantén el modo Euro activado con el V1 en vertical.
Con el modo Euro desactivado pierdes distancia de detección por lo que es mejor tenerlo activado. Con el Valentine One en posición vertical ganas distancia de detección así que puedes compensar la distancia de detección que pierdes al desactivar el modo Euro.
Ni en Portugal ni en España hay radares móviles en banda K así que ten la banda K desactivada. Ten en cuenta que la banda K es la misma que se utiliza con la mayoría de los sensores de puertas automáticas así que tendrías muchas falsas alarmas con la banda K activada. No hay necesidad de tener la banda K activada ni en Portugal ni en España.
SI seguís en inglés en esta zona, habrá sanción.
Yo lo entiendo pero hay gente que no tiene porque entenderlo.
Pido disculpas,
la única razón por lo que hago es tan simple.
Muchas palabras en español no lo entiendo, a continuación, la traducción es peor, yo no entendía la respuesta.
Sé que es complicado, y es un foro en español. El español es el idioma oficial.
En nombre de todos los que respondieron a este foro y otros usuarios me disculpo
Pido disculpas,
Ok,
usa esta zona en inglés
http://www.todoradares.com/foro/radar-detectors-forum-f79.html
  • 5 semanas más tarde...
otra cosa ... Puedo poner el volumen segundo de Valentine One para la banda K y el volumen principal (on / off) para la banda KA?
Usted puede existir bandas de K en el semáforo no se ha calibrado? Otra forma de detectar?? ....
No, el "volumen segundo" que dices tu es el llamado "volumen de mute", es decir, el volumen al que el Valentine One te avisará una vez hayas pulsado el botón mute o de silencio. Pero este volumen de mute es el mismo sea cual sea la banda.
Yo de ti me olvidaría de activar la banda K tanto en Portugal como en España, lo único que tendrás son falsas alarmas innecesarias. No hay radares móviles en banda K ni en España ni en Portugal, así que ¿para qué la quieres activar? ¿para que en ciudad no pare de avisarte de las puertas automáticas?
Si quieres detectar radares de semáforo o radares fijos utiliza un tomtom con los pois o un avisador de radares. En mi opinión un detector es para detectar radares móviles.
Si un radar no se calibra? Dado que la banda K conectado, puede tomar a la derecha con tanta frecuencia?
entonces me gustaría saber cuando un semáforo ... así que sé que, o bien se demora o se acelere ....
Tengo un GPS con las coordenadas de los fijos ... pero la precaución es aún poco ....
También tengo miedo porque sé que las ubicaciones de los radares fijos que el Valentine One no detecta. Sin embargo, yo no sé si lo mismo que trabajar de forma aislada para su reparación
para Portugal desliga a banda K usa solo Ka!
para o V1 te detectar los fijos tienes que poner lo v1 com euro mode off, mas perdes distancia para los moveis!
lo V1 nao puede acotar la frequencia 35,5 dos fijos e la 34,3 dos moveis ao mesmo tempo!
mete em euro mode para detectar los moveis com mais distancia e usa um gps com coordenados dos radares fijos (35,5) E VAIS SEGURO!
los fijos estao sempre la e os moveis o V1 em euro mode detecta mui bien!
meio em PORTUGANHOL mas espero que percebas
lo V1 nao puede acotar la frequencia 35,5 dos fijos e la 34,3 dos moveis ao mesmo tempo com boas distancias!
  • 3 semanas más tarde...
Hola compañeros compré mi valentine v1 ayer, y estoy teniendo problemas para habilitar el modo de euros puede alguien ayudarme? Muchas gracias ....
pressiona o botao de ligar para dentro e roda para ligar e deixa a carregar durante uns 5 segundos ate entrar no modo de programaçao.
ve este video que é mais facil :puke:
[ame=http://www.youtube.com/watch?v=SEBWWEnR5js]YouTube - Valentine One Radar Programming part 1 of 2[/ame]
no todo el mundo entiende el portugués en el foro por lo que te ruego escribas en castellano utlizando un traductor,asi todo el mundo lo entenderá.
Gracias.
http://translate.google.es/?hl=es#
ulse el botón para llamar y rueda gire y permita que se cargue durante unos 5 segundos para entrar en el modo de programación.
ver este video que es más fácil:
Buenas tardes,
En un reciente viaje a España me di cuenta de lo siguiente.
Fue delante de un Peugeot 3008 y el radar comenzó a silbar en la banda K. Brevemente pensaba que era una brigada de coches. Cedió y dejó vencer detector de continuo para que suene el coche ....
Esto es un poco extraño.
Otra cosa que sucede en algunos lugares o las puertas, el radar parece que se confunden y silbidos en todas las frecuencias .... Y con un sonido diferente ....
En cuanto a Portugal, se fija para detectar (creo que todos, al menos están ahí, pero debe estar apagado, así como algunos en España están apagados).
En cuanto a los radares móviles creo que todavía no han experimentado ninguna ... Todavía no se ha arbitrado los muebles ....
Olá a todos.
Josetrate e para que lhevas lá Banda K activada, si hay muchissimos pocos Radares en essa Banda e son todos Fixos ?
Para los Fixos, és mucho mejor lhevar tambien un Avisador de Radares o algun GPS.
Yo te aconsejo totalmente que desactives lá Banda K e que lheves solamente lá KA activada, porque lá K te dará muchissimas falsas alarmas, como és evidente.
Sé que hay pocos sistemas que utilizan la banda K (y, como tal, son pobres en Portugal es mejor ser prudente). Sin embargo, me gustaría saber si tiene un semáforo de control de velocidad o no (la verdad es que debe ser la adopción de otros sistemas, ya que no detecta algunos día de San Valentín).
